Editing the visibility of cut rebar
up till now when I edit the visibility setting of cut rebar line, and set a new color for line only, both line and pattern will be effected due to this override.
I hope that the cut rebar visibility overrides will be distributed , so we can edit the line and the pattern each separately.
Attached from AutoCAD that couldn't be performed with revit
Best regards
Comentarios
