Load families from a TXT file from a library in a language other than the current Revit session.
I would like to suggest a possibility to load family types from the library in a different language version than the current Revit session.
Currently, when trying to load family types saved in TXT from another language library than the Revit session, a warning message appears, saying that the parameters in the TXT file header were not recognized. Current workarounds for this are time-consuming, relying on the user manually changing the header in the TXT file.
The expected solution is to be able to automatically map and read parameters from TXT files created in other language versions when working with Revit in English. There is a need to use Revit in English while using family types from other language libraries, especially in multilingual company environments.
