An easier way to create Text Tag Annotation Families
Each Annotation Tag family in Revit has multiple layers of text objects on top of each other connected with different visibility parameters being on/off by family type. Often the Text objects contain the same shared parameters with only one shared parameter more or less, and then a visibility parameter is created for each Text object, and a new Text object is created for each combination of the shared parameters. This is cumbersome but the alternative to link each shared parameter to one Text object and this again linked to a visibility parameter will later create empty lines in the annotation Tag when some values are turned on and some not. The Better way would be to link the shared parameter directly to the visibility parameter within the text object in the annotation family.
