Levels and Grids - Ability to flip start/end after creation
Title says it all. Would be great, so many newbies or pros early in a project when orientation is not known place these, and later wish the default grid or level head end was inverted.
Would you care to explain more? -Is that related to API or Dynamo manipulation of the grids and Levels?
11-07-201605:32 AM
11-07-201605:32 AM
I've tried to mirror-without-copy a level after a number of objects were referencing it (masses, walls, etc.) And the relationship would break. If there was a way to separate the geometry of the plane and the default edge/side for a tag this would likely solve this, both for levels and grids.
Sorry I am still confused - please explain why would you be mirroring/flipping grids or levels especially if they stay on the same plane as before?
(The only reason I could think of is if you are coming from Autocad and want to flip the bubble?)
11-07-201606:40 AM
11-07-201606:40 AM
Yes, correct. The ability to change the DEFAULT side the level tag or grid head shows up in for new views and/or existing views. I know you can manually check/uncheck which side the tags show up on, but changing the default globally would save a lot of time. Also, selecting multiple grids or levels in a view and being able to check a start/end perameter for level tag / grid head visibility.
