Area Color Schemes
I want to be able to use the same color scheme across projects, and across different area plans - why do i have to re-create the color scheme because i need a new Area Category?  for instance, the city calcuates area differently than the building code.  Therefore i need to create 2 "Categories" but i wish for them to look similar, with the same color schemes applied.  why not allow me to select the same color scheme?  instead i have to rebuild it from scratch?
Comentarios
Currently having the same problem, hopefully this issue gains the support of the community and can be pursued
Transfer the area scheme and area color scheme to a new model. Open the new model and rename the area scheme to match your new area scheme. Transfer them back to your model.
