Control upon Revit Annotation (Keynotes, etc) leader elbows
Most of the times, it becomes a hassle when dealing with Revit's annotation leader and controlling the elbow point. Sometimes, it is just enough to have no elbow or sometimes it may require multiple elbows for the leaders, depending on the needs of positioning the text on the sheet. Obviously, it is not about removing the leader line through properties palette, which will entirely remove the leader line.
I have searched everywhere, and I'm unable to find a workaround for the same. If there's any suggestion, please let me know. Or, if you think this is a need as a feature, please up vote!
Comentarios
Hi, @tdtharinda
Here are two similar Ideas...what do you think about combining yours with them?
Tag Leader can have 2 break points or be a spline - Autodesk Community
Multiple Elbows in a leader - Autodesk Community
Thank you for your submission!
-Kimberly
