Automatically Add Shared Parameters from Family
It is a huge pain to have to add shared parameters to the project in order to get different titleblocks to work for instance. It would be nice if the parameters in the titleblock loaded in automatically when you loaded the titleblock. You would have to define the shared parameter in the family first though so that it would know to be an sheet instance parameter verse a project parameter or sheet type parameter.
I know some will say to just load all these in my template but then I would have to have a separate template for every client or have every parameter loaded for every project.
Comentarios
