Area Boundary Pick Lines
Provide ability to select multiple walls at once using a selection window similar to the way you can when creating columns at grid intersections. When integrating Revit models to space management systems often there needs to be a one to one relationship between Revit Rooms and Revit Areas in order to get the proper area for each Room per the appropriate area calculations. Having a way to mass select walls that represent boundaries would increase the speed to create these and other Area Plan drawings.
Comentarios
