Modifying Sub-elements does not allow you to use ”Backspace” key but only ” Delete” key in order to delete lines or points
Since most of the time those two keys are doing the same thing, could you please consider having only one of them doing the same action? What is the point of having them both active, performing the same function?
Moreover, it turns out that in some situations one of them might not work properly as with the ”Modifying Sub Elements”.
Please have a look ![]()
0
votos
