Model Pattern Bricks
I cannot find a way to draw bricks in elevations "right".
The "patterns" that I find are based on grids of 0.24 m.
I am missing grids of 0.25 m. (0.24 + 0.01 for the grout).
I would like to find something based on patterns like
theses in the default templates...
PAT:
;;This is for information only
;%UNITS=MM
*zz_mauer_250x125,250x125
;%TYPE=MODEL
0,0,0,0,125
90,0,0,125,125,125,-125
PAT:
;%UNITS=MM
*zz_mauer_250x125_10,250x125 10mm
;%TYPE=MODEL
0,0,0,0,250,240,-10
0,0,135,0,250,240,-10
0,125,125,0,250,240,-10
0,125,260,0,250,240,-10
90,0,0,0,250,-135,115
90,-10,0,0,250,-135,115
90,125,125,0,250,-135,115
90,115,125,0,250,-135,115
Comentarios
I have used some hatch editors (as described in this thread) in the past to get the results that I was looking for. I have also found a lot of patterns from stone and masonry manufacturers. For the most part, I used editor to convert .pat files from model to drafting and vice versa. It's been so long since I've done it that I don't remember the exact process.
Check out us at pattycake :tarta_de_cumpleaños:
We have a bunch of these pre-built in library for download (over 400+ for free), and a brick/tile creator template which allows you to make any size you need part of our PRO features. And no ancient add-ins to install.
PS. Our herringbone template is completely free to use.
Pattycake! That's the one that I was trying to remember the name of. Glad you chimed in @Pattycake_Kyle
