In Autodesk REVIT, while selecting elements, you can press the TAB key to sequentially display the selectable elements near the mouse cursor.
When you press TAB the status bar updates, indicating the current selection: any chains of connected elements available near the cursor are included in the selectable elements, allowing you to select all elements of the chain at the same time.
This can be a problem for a LEFT-HANDED user because he has the mouse in his left hand and it becomes difficult even with the same hand to use the TAB.
In some link on REVITFORUM suggest Apps to be able to remap the keys on your keyboard.
It would be useful if this association could be done inside REVIT as it happens for other functions from:
Option -> User interface -> Keyboard Shortcuts
Many thanks for colaboration
