Tag all parameters of System Families
This is rather self-explanatory. For some examples of parameters which cannot currently be tagged:
- The "Base Constraint", "Base Offset", "Top Constraint" and "Top Offset" parameters of Walls
- The "Maximum Ridge Height" parameter of Roofs
- The "Height Offset from Level" and "Thickness" parameters of Floors
These seem to be simple values which could be provided in the list of parameters in the Label menu (see image below) when creating a tag.
