Create Similar, but w instance parameters, so you can keep drawing a wall.
We should be able to just click on a wall/window etc... and keep drawing it. Same type parameters, same instance parameters. I can't believe we have to copy paste a wall when we want to keep the same instance parameters. You have a create similar tool, why wouldn't you have a create similar that also copies instance parameters? This is what's actually needed 99% of the time.
