We would like to see an automated routine (similar to "Reinforcement Volume") where Mass (kg) is calculated. I suggest having a Type Parameter - Mass unit per lenght. Then this is multiplied with the Rebar Length "on the fly".
See attachments.
The Dynamo-graph is just example. This should be built in.
