"Search and replace" : zoom to result and don't prevent working
I would like to be able to zoom to the result when I'm using "search and replace".
Right now, this function pop a window and everything else is forbidden while this window is there.
I would like to be able to search for a word, zoom to it, modify what I need to and continue the search.
Exemple ; someone used the wrong text and writes it on 2 lines. I needed to find those texts and edit them to be correct and on 1 line. I could'nt easily use the "search and replace" because the words where on 2 lines and Revit was not able to find them correctly.
I could achieve the result by removing and adding words, but it's a little complicated.
If it could highlight the results on the drawing and not prevent to work, I could have searched with a word, select a result, zoom to it from a button, one at a time, to modify them quickly.
