Text formatting
It would be great if text could continue into the next column on a page. (see how Photoshop InDesign does continuous text). i.e. one large sheet could have multiple columns (for readability) - if you add text to the first column of text then the text in the other columns should shift to accommodate.
This would be great when copying over large text documents onto sheets - i.e. general notes, specs etc
