Revit Links - General Switch off button
There should be a general switch on/off button to control the visibility of all "Reference Planes/Lines" from ALL Revit Links in one go, without having to open the display settings for all of the links one by one.
The same  for Levels and Grids,
With so many links in one project, the task becomes time-consuming
Attached a snip of where this option could sit,
Oswaldo
Comentarios
It can be done with filters, though takes experimentation with naming - that's what we do for levels and grids.
The 'imported categories' provide an example how this could be done.
@MichaelWolff  I think you are thinking of something like this, which is what I thought Oswaldo meant initially too.  He's talking about a faster way to change certain display settings for the links.
