Revit Section, option to lock section "heads" to section "extents"
See the image for context. Basically there should be an option to lock the bubble heads together with the dashed section extents. This would require the user to only have two drags instead of four to modify the extents of a section. This would be very helpful in "busy" or "cluttered" areas where it is often hard to keep track of sections and their extents.
Comentarios
Intuitively, this would be the default, both from efficiency and from WYSIWYG design. I would expect it to have to be actively unlocked to separate.
@NateBrushRight? You should have to choose to separate them rather than to keep them locked together if this ever happens!  :cara_con_una_leve_sonrisa:   The majority of sections used in Revit are "working" sections. I haven't had to do a ton of production work in a long time and this is a glaring issue.
