Wall Wrapping
It would be much more useful to have these two parameters "Wrapping at inserts" and "Wrapping at ends" as an Instance parameters instead of Type parameters to eliminate the need to create multiple types of the same wall.
Comentarios
Is it possible to take the wall Wrapping type parameters and change them over to Instance parameters?
I was reading about an older thread where a recommendation was made to create separate wall types, one with wrapping and one without. I believe that we could all use a more elegant solution to this problem.
I sometimes use wall wrapping for internal walls where the wall ends with no connection. the problem is when I must break a wall for a steel column, I don't want the the plaster wrapping next to the column, there I will put expansion material and wall ties. in this case I need to create a new wall type with the suffix no wrapping, It would be much better to make the wrapping function an instance parameter as so there is no need to make multiple wall types. there are many other instances where there are differing wrapping conditions for walls.
Yes. I have a very large and complex project and it contains hundreds of wall types. Many of these are purely because we need walls to wrap differently at ends. Why in the World is it not instance based? Could it not at least be both instance and type based so we can choose ourselves? And whilst your at it, perhaps it would be best to be able to set it individually. Like right clicking and changing the wall end to disallow or allow join. Could this be an easy way to deal with these odd variations? It needs attention to allow us more flexibility in our modelling and getting more out of our model/drawings without overmodelling.
Those are my feelings exactly. We are getting to the stage where contractors are grabbing their building information directly from the models, and being able to fully model buildings as they are to be built is becomming more important. it seems to me that revit could do more towards making their platform a one stop shop as opposed to being held ransome to countless add on merchants.
A function within the control of the wall end that allows "wrapping on ends" for individual wall ends would be nice. When we right click on the wall control node, we have the option within it to disallow join. An extra option to allow wrapping on ends would be great, rather than making 2 versions of the same wall, one that wraps at ends, one that does not.
I don't suppose you could show examples of where you would need a wall to wrap and not wrap?
This would be terrific. Our office often must duplicate wall types just to provide wrapping versions.
The four default wrapping options are shown below in a standard GWB wall. None of them are ideal -- I've bubbled where each does not correspond to how I would like it to look for my work. Your preferences might well be different. Since I rarely use uncased wall openings, I would use C (good for doors, good for wall ends) and use the requested tool to add a wrap at the wall opening. As it stands now, I'd have to split the long wall in C and change the lower half to B, with possible consequences farther down the wall.
Thanks, Bill! It sounds like it would be even more helpful to differentiate Window and Door Inserts in the Wall properties... or maybe even better to have it a property of the Window Family/Type? That way you wouldn't have to adjust individually...
It should work the same way it works in ACA with end caps, where you can design as many different conditions (ex. inside corner, outside corner, window and door jambs..etc) and be able to assign it to any side of the wall.
There ways around in Revit, however, it is not streamlined to make it practical to use.
@kimberly_fuhrman-jones  I think this idea needs to be combined with https://forums.autodesk.com/t5/revit-ideas/wall-wrapping/idi-p/9775476
Even combined these don't have many votes!  Come on people!!
@Ric_Weber Thank you!
Team,
It is most helpful to everyone's ideas to present related ideas to everyone to vote for those as well.  In the case where we think that the ideas are essentially the same, we should let @kimberly_fuhrman-jones know that we think the two ideas should be merged.  This will combine their votes and get more attention that way.  Don't forget to use the @ to get her tagged, so she will see the post.
Kimberly,
Several of the ideas that @wr.marshall posted above should be merged with this one I think.  Not all, but several of them.  Also, of those that don't fit merging with this idea, I believe those could possibly be merged into one as well.  I'll let you be the judge of that.  Thank you!
@Ric_Weber
Agree with your statement for most ideas. Though my idea of drag and drop wall layers in a wall join is a different idea, the philosophy could probably be applied to wraps, especially if wraps become instance based.
I didn't feel the above links warranted a combine as all asking what appeared to be different specifics with regards to wall wraps.
I do regularly tag Kimberly when I feel an idea is the same.
@wr.marshall
I agree your idea of the drag and drop wall layers is separate (although related) from this idea, but in my mind at least 2 of the ones you listed are the same as this one.  That's why I thought a tag to Kimberly was worthwhile.
You and I are of the same mindset, I believe, most of the time.  Like you did in the comments of your drag and drop idea, I was also letting others know about tagging Kimberly.  Just a small difference in thought process in this case I guess.  :cara_con_una_leve_sonrisa:
@Ric_Weber @wr.marshall ,
You both make my job so much easier, and I thank you all for pointing out when you come across duplicates. As much as I try, sifting through over 9000 Ideas does take a village. I will take a look and make a determination on the links above. Thank you for your contribution to our Revit Ideas village!
-Kimberly
Since wall wrapping at inserts has 4 states and wall wrapping at ends has 3, that means there are 12 possibilities - which means you would need 12 copies of each wall type to capture all these options!  Why this is not an instance parameter is mind-boggling.  AutoCad Architecture has had a similar feature with "End Caps" that is instance changeable for over 15 years.
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our Revit Public Roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing.
The Factory
Thanks for your submission and votes on this idea! The idea to disable/enable wall end wrapping by instance has been accepted. See the public roadmap card here. Note this does not include insert wrapping by instance as the original post suggests at this time. However, we continuously evaluate requests as we make adjustments to our roadmap and will consider this in the future. Thanks for the submission and keep voting!
@lauren_poonRM962 That's nice to hear, BUT... that means this is going to become another one of those ideas that Autodesk half-implements, and then checks off as "done" so the marketing department can say "look how many user ideas we implemented in this release!", then someone has to go and re-post the idea and start all over again for the other half... (for example, adjustable row heights for schedules was "implemented", but not for revision schedules...)
That said, something is better than nothing, and I can appreciate the 80/20 rule as I use it frequently... (although with Autodesk it usually seems more like 60% of the job done for 20% of the effort...) Thanks! :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
@lionel.kai We appreciate the feedback and will consider this going forward.
This one is pretty self explanatory. Why not include a bit more wrapping functionality within the instance parameters of walls?
Sometimes the need for wall wrapping is confined to only a few instances and changing the parameters for an entire type doesn't make sense, furthermore I don't like the idea of creating a new type for a couple instances and polluting the type browser (We all know how quickly types can add up).
Dave
Yes, please add.
El estado se ha cambiado a: Implemented
Implemented
We are pleased to say that this has been implemented in Revit 2025! Thank you for your contribution to improving Revit!
Help | In Canvas Wall Wrapping Control | Autodesk
 -The Factory
