Enable Dynamo when editing in place Mass in Project
Hi All,
The title is pretty self explanatory, I would really like to have the option to fire up Dynamo when I'm editing a Conceptual Mass within the project environment.
I understand this might have been turned off due to technical difficulties in running Dynamo on top of Revit and making it point to the correct document. I think there could be a button allowing the user to point to the correct document that they want Dynamo to run from.
Best regards,
Jan Kocjan, PLH Architects, DK
Comentarios
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
Hi! I would like to bring this idea back! I love using masses and concept designing in Revit. I'm a full believer. I wish there was just a little more TLC when it comes to MASSES. I use conceptual massing, divided surfaces, and dynamo to create parametric facades. However, dynamo does not work in the "in-place mass" environment but it does work in the "conceptual mass family environment. I typically work in the "conceptual mass environment" but there is an issue when you want to bring a Rhino .3dm file into the workflow.
Currently right now my workflow is linking rhino files into the "project environment" as an in-place mass and then that lets me divide the surface. However, I would like to be able to do that in the "conceptual mass environment" but it's not possible. The reason why I want to work in the "conceptual mass environment" is because dynamo does not work with divided surfaces as an "in-place mass". So anytime I make a parametric facade using divided surfaces and dynamo, (depending on the complexity) I painstakingly have to remake the geometry in the "conceptual mass environment"
The ability to edit in mass using Dynamo would be an absolute game-changer for me and my company. Please reconsider this!
