The default colors in Revit are rarely what you want
Often we have a company Color Standard
It would be great if we could customise the default colors
You probably mean the colors of Revit itself? Check out the Themes folder:
C:\Program Files\Autodesk\Revit <year>\Themes There are two XML theme files you can modify yourself.
Would be nice if someone made a simple tool to change those themes.....
Hi @Simon_Weel
Thanks but I am referring to the Default Colors of the Color Scheme, as per my knowledge there is no possibility to change this. Neither is there API access to my information
