Cut through .adsk model from Inventor
In Revit 2017, importing an .adsk model made in Inventor yields varied results.
Sometimes the model will not show in a section view and other times it will.
Sometimes it will cut in a section going one way (ie: viewing north) but not the other (viewing west)
Sometimes it will cut just fine.
They will always show if they are not being cut through at all.
The instances are completely random.
Issues were usually solved by changing the model to an assembly before converting in Inventor, other times by simplifying it into a part.
Other solutions were to save the .adsk model to another folder.
Some could never be solved.
Making these two programs work together better would benefit everyone.
Comentarios
I was having this problem Revit 2017. Sections of ADSK families worked in 2016, even with very large ADSK files which didn't section properly in 2017.. Good new is that the latest version of 2017 seems to have fixed the problem. Yes, we really need Revit and Inventor to work better together.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
