Elastic Search - Material Parameter Field
This type of idea would apply to a lot more in Revit but in particular I'm struggling today with populating the Object Style Material column. Revit needs an Elastic Search available here when trying to find materials. It helps when I can copy/paste from another cell but that is not always the case. Rather than have to open the Material Editor itself and search in there for the appropriate material it would make my life ever so slightly easier if I could just search for a material in the Object Style table and then get prompted results as I type.
This could easily apply to schedules or anywhere else that displays the material in a tabular format. When I'm inputting material information I do not necessarily need to go into the editor if I know a material already exists that I want to use. Having the elastic search to give me project results in the same dialog box that I am actively working in would save precious time.
