Text Wrap in Properties Palette
It would be nice if you could wrap text in cells in the Properties Palette, so you can see the values and modify them easier. Every time I work on a Keynote schedule I find it difficult to see the text I've typed and modify it if necessary. I know I could be using a schedule to input or modify these values, but adding this to the Properties Pallete would be way easier.
Comentarios
We need parameter text wrapping in all dialogs. Type Properties, Global Parameters, etc.
