Pipe/duct filling pattern other than solid in Revit
The user suggested that it should be possible to choose a different pattern than solid for pipes or ducts. At the moment, the color of the displayed installation section depends on the material selected in the system:
Even if in material properties a pattern for Surface or Cut are selected, they are not displayed on the view:
Setting the View Range in the pipe/duct axis does not change the display either and the solid pattern is visible:
Users would like to have more flexibility in choosing patterns and presenting the system in views.
