3D Views: Export File Name Without Prefix
When exporting a set of 3D views to DWG there are two options for the file name outcome (Automatic - Short & Automatic - Long) but what if you just want the exported file to just be the view name?
A normal MEP coordination workflow depends on keeping the same consistent file name (since they are typically appended in a Navisworks coordination model already and also to keep a structured file system among trades) and just overwriting that file with any new changes. It would be nice to be able to just batch export all new files, without the need of using additional software to remove the unnecessary prefix on the front end of the file name, or exporting them one by one (which is time consuming and tedious on large scale projects)
