Make the view windows usable again (Tab and Tile "updates" are a waste of time)
When working with a dozen+ windows open.
In 2018 I could 1. tile all views with a keyboard shortcut, 2. with ONE click maximize any view, work on it and 3. tile them again with a keyboard shortcut to have all views tiled to switch to the next one.
Now, to do that in 2020:
1. keyboard shortcut to tile the views
2. click on the view I want to maximize,
3. click and drag it to dislodge it from the tiles, (you can't just drag it out when switching between models)
4. then click the maximize button that finally is visible. (when working on one screen the view takes the entire screen and you can't see Revit, properties, project browser or the ribbon)
5. reshape the window so you can see both the view and Revit.
You work on it, and when going back to the tiled layout to "quickly" switch to another view, you have this dislodged view that will not tile with the others...
So now you need to:
6. click on the non tiled view,
7. snap it back to the tile layout
8. hit window tiles to get then nice an neat and do steps 1-5 again to switch to the next view.
Now how does that 13 step process (no pun intended), compare to the 3 steps that we had before?
