Allow Built-In Parameters to Change Between Instance and Type
Sometimes a built-in type parameter needs to be an instance parameter for certain families, and vice versa. But we can't control this, so please allow us to edit this per family. This has caused us to abandon several built-in parameters in favor of our own shared parameters.
Example: Apparent Load is a built-in parameter for lighting fixtures. But some lighting fixtures have per-instance properties that can change the load. So we can't use Apparent Load - we have our own shared parameter.
Another example: For electrical equipment, Model Number is a type parameter but Max # Breakers is an instance parameter. If a panel has a different number of breaker slots, then it has a different model number, so these two parameters are incompatible with one another. We need to either change Model Number to instance or Max # Breakers to type. Similar for Enclosure - a different enclosure means a different model number.
Comentarios
@scbunker: How exactly do you want this working?  There should an additional parameter to control your parameter type: instance or type ? How should Revit know when it should be instance and when should it be type?
Would it be simpler to create 2 parameters: Load_instance_param and Load_type_param. Revit should give us some graphic clue (icon/graph) when a parama it instance and when it's type.
@ipselute, why shouldn't you be able to just edit the parameter (by clicking the pencil icon) like any other parameter and change it from instance to type or vice versa? There already is a graphic clue within the family editor as to which are instance or type. Instance parameters have "(default)" after their name in the family types dialog.
There's a weird snag in this case. When using the Family Types window, you can't switch those parameters between instance / type - it's greyed out. But if you select the dimension itself, you'll notice a checkbox Instance on the Ribbon. Check it and voila...
Community Visitor
Community Visitor
It would be very helpful with door families to be able to have an instance parameter for whether a door is fire rated or not. Right now you have to duplicate the family. There are already enough families in any given project, this just makes it more cumbersome.
https://www.redcage.ca/blog/how-to-change-a-revit-parameter-from-type-to-instance/
This works for the Fire Rated door parameter. But i cannot change the OOTB parameter Description back to a type. How did this even happen?
@curtisridenour
Click the Edit button (pencil icon).
Somewhat relevant, but perhaps only applicable to length parameters or others you can set up a dimension against.
https://therevitkid.blogspot.com/2017/02/revit-tip-modifying-built-in-parameter.html
I have the same problem @curtisridenour
The description looks like impossible to change.
@ToanDN
