Access Mass in mass subcategory schedules
We use mass families for programming blocks. Often we'd like to schedule the level the families are placed on, which Revit doesn't offer. The alternative is to create a mass floor schedule, which works fine until we need to show a mark or instance category/description of the mass the floor is in. For any of the mass subcategories it would be helpful to be able to schedule their information alongside information in their hosting mass. I'd see this working the same way scheduling rooms in a door schedule do, where the option to schedule available fields from "Mass" is a choice.
(While there are a few mass fields, like type name and comments, are available now, project parameters and shared parameters added to the mass family are not options)
This would allow a quicker generation of programming information, and less chance for mistakes. Currently a user instance parameter must be filled in for level on the mass, or program space name and mark information must be copied from the mass into the mass floor and manually coordinated
