Dimension to midpoint of detail line or elements
Snapping a dimension line to the midpoint of an elements. For example two columns in between is a beam can measure the midpoint of a beam.
Comentarios
Right now you can snap to the middle of a line but not dimension to that point.
Often, circles are 2 arcs and you can only dimension to their endpoints. Please add middle points as a snap on arcs, and give us the ability to dimension to that point as well!
See this discussion on AUGI for proof of a general desire for this feature.
https://www.augi.com/forums/showthread.php?164293-dimension-to-midpoint-of-detail-line
Here is a similar Idea. I can merge the Ideas and Kudos if you like!
Dimension to midpoint of detail line or elements - Autodesk Community
