Support ifc (stored in the cloud) in nested links in cloud worksharing
On behalf of a customer from Germany let me post the following wish:
Currently IFC files, stored in the cloud,  won't appear through nested links in a cloud worksharing model. Request is allow the support of IFC through nested links in cloud worksharing.
This issue impact not only ifc, but non-workshared nested links as well. See this article.
Comentarios
That Revit IFC links work the same way than rvt / dwg / dwf links.
Currently when having a revit file with linked IFC, on upload linked files we cannot select the IFC files nor do they get displayed whan viewing in the browser.
Nic Maes
Same issue here, but how we solved this scenario at the moment is
1. We link in IFC file to Revit and saved it. In this case, Revit will generate <Name> ifc.rvt at the same location of linked IFC folder.
2. We remove original .ifc link file, then link in back Revit generated <Name> ifc.rvt file and save the Revit file again.
3. So when we upload to BIM360 docs with link file, we can choose <Name> ifc.rvt file as the link file.
P.S We try this workflow with Revit 2017 version. We havn't test with old version yet.
El estado se ha cambiado a: Under Review
Has this Issue been resolved yet ?
If so what is the BIM Workflow.
Hi there,
I am also interested in if this idea has had any further progress since being changed to "under review" in September.
Can anyone from Autodesk please provide an update?
Christian
yes, a very important feature for specialist sub contractors to be able to display their model in the federated 'design collab' model.
Hi @joan_allen, just following up on this again - IFC links still are not visible via the BIM360 docs web view as part of a federated model view. This is basic functionality that needs to work!
Christian
Hi  @joan.allen
any basic federated model viewer can import ifc. This needs to be integrated into docs/design asap, or suitable workaround advised. Revit is a great tool, but does not have many specialized functions that other specialist BIM tools have, so we cannot expect entire supply chain to be on Revit. this makes docs/design unusable at constuction stage and required entire model to be exported to Navis, which defeats the purpose of Design Collab. At nearly 1k for a single user license, this fundamental item, outstanding for over 2 years is hardly acceptable.
Any Update?
Regards
same problem here..
Hi @joan_allen,
Just another follow up on this thread - could you, or anyone else in the BIM360 docs team please provide an update on this much needed functionality - was it ever reviewed?, Is it on the BIM360 roadmap?
To recap, the core functionality needed is being able to view a model and all its links (Revit cloudshared or not, IFC, or other) within Docs itself (avoiding the use of "Model Coordination" or "Design Collaboration" which inherently add more steps to the process).
Christian
Still the same problem.. :cara_de_decepción: Please update BIM360 so we can use IFC-imports as well in BIM360 docs.
Thankyou!
Just ran into this today... Super important to incorporate this ability! - Please Autodesk make this happen.
Chuck
Also running into this problem. I tried the sollution given to link the IFC into an empty RVT but it doesn't show any geometry then in Bim360. It's a need-to-have with this software!
.. any response..
Any progress yet ?
This crumbles the whole point of BIM field collaboration and open bim mindset.
To find a post like this after hours of trying and struggeling to get a linked IFC to show up in BIM 360 (because we where thinking no it is just our own fault we are probably just doing something wrong),
wich in conclusion tells that it is not possible at the moment is just a shame !
Get your stuff togheter autodesk, maybe do a rewriting of the Revit roadmap,
stop inventing new stuff focus the developing bugget on fixing everthing that is not working properly at the moment.
@benschilders  , yes we have a workaround for now. I had contact with Autodesk Bim360 Design support. They told me ifc linking is not supported in Bim360 Docs. They advised me the following workaround, which we don't use but it may be helpfull to you.
1) Open a new Revit model
2) Import IFC and save te model
3) Link this new Revit model to parent model
4) Upload new linked model to Bim360 Document Management.
We tried it and it didn;t work for us. Our solution:
1) Under the project in Bim360 docs, under Project Files, create a folder IFC
2) Upload the IFC's to this folder
3) Open the Revit main model en link these IFC's
4) Bim360/Revit automatically converts the linked IFC's to ifc.rvt in the same folder. Don't wait for it, it can take hours. Do something else instead en check again later if all the ifc's are converted
5) Open these .ifc.rvt's seperately in Revit and collaborate them in Bim360, but not under the IFC folder, since you can't collaborate a file when a file with the same name is already there. Use another folder under Project Files to store these converted ifc's.
6) Open the main model and load these ifc.rvt via external resources (which only shows collaborated models)
7) Synchronize your main model
:cara_con_gafas_de_sol: Make drawing sets under Publish Settings
9) Publish the model with Manage Cloud Models.
And voila, everything works flawless. Good luck with it.
We really need this IFC linking in BIM360 Docs.
Autodesk, please be advised that  Graphisoft is said to support this function in its BIMCloud product, which would be the competitive product of BIM360.
@r.waandersEF3FP
  Thanks for your reply it realy got us started. (sorry for the late reply
wanted to realy test stuff before replying).
The thing we do diffrent now is not uploading/collaborate before step 5.
The reason behind this is that creating an automatic RVT from a IFC by linking it also works fine offline.
In our testst it showed that this saved time with:
1/ not having to upload  original IFC to BIM 360
2/ not losing time when your trying to link from the BIM 360 (with me it sometimes takes a long time
opening the path finder and vice versa with navigating trough it when using external content
(hope pathfinder is the correct term))
3/ Revit does not have to upload the automaticly created  ****.ifc.rvt (and other files like the log) to the cloud
4/ Opening this automaticly created project is faster from the local server than from BIM 360
The diffrence in time may seem marginal, but with big industrial projects it is worth it to do the first steps offline,
So the current workflow we use now and works the " fastest " for us is:
1/ On local server in the project map create a folder IFC to RVT
2/ Save IFC in this folder
3/ Open an emty project and link the IFC's into here
4/ Revit automatically converts the linked IFC's to ifc.rvt in the same folder.
5/In a separte Revit sesion open the RVT created in step 4.
6/Collaborate this rvt model to BIM360 ( we use a seperate folder for example "IFC to RVT"
, because in my tests the links wouldn't show up when placed the same folder as the main model).
7/Open the main model (host) and link the collabrotated ifc.rvt's from external resources
8/ Setup the publishing set (and make sure there is a 3D view in this set  in our test we had problems with links not showing up when there was no 3D view in the published set even when the order (step 1-7 was followed)
9/ Publish model
A note to Autodesk:
Fix your stuff or at least make comprehensive/understandable tutorials for stuff like this.
After years of using Archicad in my study time it is a real bummer to work with Revit,
sadly our local field is Revit dominated and it would cost to much to re-eduacte our older collegeges
. (and i am not talking about not having enough knowledge about Revit,
i am talking about restrictions mostly because of the category system.)
Again thanks for the reply !!!
it was way better then the solutions that autodesk has on there multiple websites.
Wich are in many ways confusing.
Nice to hear @benschilders  and thank you for your follow up since we all can learn from that.
There's another way to go with this, since it does takes time to load in the ifc's in a project. You can't do this in batch and it needs to be done one by one  so it will need your continuous attention. And you can only go on with number 2 if number 1 is finished loading. So I tried the following and this worked even quicker.
I had to convert 12 IFC's to RVT's yesterday. I opened Revit2019 12 times. Went to the first Revit version, file>open>ifc and opened ifc 1. While it was loading, I switched to Revit 2, opened ifc 2 and so on. When I was finished opening 12, 1 was already loaded. Go to 1, save as rvt, collaborate, done. Go to 2. And so on. It took me only 2 hours to convert 12 IFC's, convert them to RVT and have them collaborated. Those were giant IFC's of almost 1Gb, they ended as a 30Mb RVT. Link those with external resources in your main model and you're done even quicker.
@r.waandersEF3FP
Deffinitly gonna try the open IFC method instead of linking it to create a RVT. (1Gb to 30MB is astonishing)
Do you use the IFC add in from Autodesk, just curious ?
OFFTOPIC:
Also if you are working with Archicad partners i really recommend the Graphisoft IFC export extension.
It helps with making the IFC more compatible when imported in Archicad for your partners.
The method of opening more than one Revit session is the same method i use it really helps speeding up the process,
instead of waiting your'e stil working and the process keeps running, even better when you use the empty spare pc (if the company has un used pc's, we have because of a dismissal, so thats the way i do it.)
Keep u the postive vibes and togheter we might get the best out of the Autodesk products :símbolo_para_indicar_que_todo_está_en_orden:
@benschilders  Yes I use the IFC add on from the Autodesk App Store. Beside that, I use a standarized and optimized IFC template and IFC im- and export mapping table. The problem with IFC's is that the quality of it depends on how a third party exports it from their software. If that's done not properly...you can fill in the rest.
This is actually a part of a larger problem. Which is that non-cloud workshared models are not visible as links when viewing an actual cloud workshared model in browser.
Usually this means .RVT files converted from IFC files but it can be something else too. E.g. Tekla can export structural models as .RVT files but that doesn't help if it's not a cloud workshared model.
And initiating models as cloud workshared models every time they get updated is unnecessarily burdensome and I think it also requires you to delete the previous model in BIM 360 because you can't initiate a new one on top of the old one with the same name.
One other option that we have tried to look into is to save those converted RVT files with Save as Cloud Model function. But we haven't been able to test if those would be visible in browser as links or if you can save an updated RVT directly on top of the old one because that of course requires some other license that is not included in the BIM 360 Design license ("Cloud Models for Revit" instead of "Revit Cloud Worksharing" https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles... ).
@Anonymous, PLEASE consider resolving the inability of bim 360 to handle linked IFC files. On our current multidisciplinary civil infrastructure project, we have literally 100s of IFC files that get updated weekly and simply don't have the time to open each Revit file separately to create workshared cloud models. Hence, we are forced to keep these IFC files offline on our local server - not ideal for collaboration, especially in this pandemic-age :cara_guiñando_un_ojo:
This is hardly a novel idea and it has been flagged since the inception of bim 360. Please sort this out as a matter of urgency............ no, the workarounds don't work with nested linked IFC files and the notion of manually creating workshared models of hundreds of weekly updated IFC files, is not an option.
Hi, @charl.maraisJGPAX ,
Here is a similar Idea: Support ifc (stored in the cloud) in nested links in cloud worksharing - Autodesk Community
If you think they are similar enough, I will combine this one with yours.
Thank you for your submission!
Kimberly
Is there any solutiuon about this topic nowadays?
Autodesk Support
Autodesk Support
Adding this request from one of our enterprise customers based in the UK
They are asking for IFC files to be managed in BIM 360 as if they were native Revit or AutoCAD files.
REVIT-126918 and REVIT-167696
What is the best method to work with IFC on Collaborate Pro (Revit 2020)?
As another large enterprise customer I want to put my support behind this request.  We are also working on large infrastructure projects and others like Pharma and water with IFC files from multiple other platforms.  The current workflow (workaround!!) is a huge burden to the projects.  Nesting and updating IFC links needs to be as simple as with .DWG.
We have several customer having the same issues. Showing linked IFCs should not be an issue at all.
Everyone are working with IFCs alle the time. This needs to be fixed.
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
@shaun.r.clough ,
As stated in my post, Accepted Ideas may not be immediately available on the public roadmaps, however they have been included in our teams' internal roadmap. Confusing, I know, but once it hits a certain point in development (I don't know when), it will be added to the public roadmaps and Revit Preview.
@benschilders and @r.waandersEF3FP I understand your workflows, however how do you manage change when the IFC files are updated?   Currently, you cannot overwrite a cloud work sharing or save to cloud Revit models.  Which forces you to delete the previous IFC.RVT and create a brand new one, which creates a new GUID in BIM 360, which plays havoc with Model Coordination and Assemble.
hey Autodesk, how about a better workflow? :cara_con_una_leve_sonrisa:
Autodesk, facilite el Open BIM, consideren permitir el reconocimiento de vínculos IFC dentro de la ACC
@Orsolya.Balazs @kimberly_fuhrman-jones Almost a year since the 'acceptance', is there an update yet?
El estado se ha cambiado a: Implemented
Per the product team, we are pleased to say that this has been implemented in Revit 2025! Thank you for your contribution to improving Revit!
 -The Factory
@kimberly_fuhrman-jones , okay I'll bite, where can I find more information on how Revit 2025 resolved the linked IFC issues with ACC/BIM 360?
@shaun.r.clough ,
This was considered a fix, so just a mention in the Enhancements section of the Release Notes for Revit 2025.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=RevitReleaseNotes_2025release_Enhancements_html
What this fixed:
  • Nested IFC files that are loaded through Desktop Connector will be loaded and shown in cloud workshared models
  • Nested RVT files that are loaded through Desktop Connector will be loaded and shown in cloud workshared models
@kimberly_fuhrman-jones I just tested this with ACC, Desktop Connector 16.10 and Revit 2025.2 and the ACC Viewer still does not show a nested (linked) IFC file.  Can you confirm that this is fixed?
I just tested this and it is still not working.  The ACC viewer is not displaying nested IFC linked models in Revit 2025.2, using desktop connector 16.10.  Can anyone confirm that this works?
@shaun.r.clough , this fix addresses nested links within Revit Cloud Worksharing, not the published view in the ACC viewer. That is a different issue. This, however, is also on our roadmap. I am not finding a Revit Idea that relates to the viewer, so feel free to add one!
@kimberly_fuhrman-jones The ACC viewer was the basis of this idea.  If the ACC viewer cannot see the Revit linked IFC files, then it cannot be used in any upstream ACC modules such as Model Coordination, Clash Detection or even Assemble.  Several of the comments from users point out that exact deficiency in the tool.
Thank you for the feedback, @shaun.r.clough . The original idea is what was implemented per our product manager, and as I said, the ACC viewer issue is on our roadmap.
