"No Override" in Graphic Override setting
Hi, woud be nice if the "No Override" could work in "Graphic Override" setting for phasing.
I want to keep "by components" pattern defined in "Materials" setting as foreground while adding a solid gray in the background for existing component.
Right now I have either to replace it by a solid gray and write the description or keep the pattern and draw a gray pattern over it...
votos
