To ease my work I combine Families into a host family and nested families. The parameters of the host family and the nested families are connected. Example a "Roof Hood" (nested family Nr. 1) and the associated "Roof Opening" (Nested family Nr. 2). Now the Host family is placed a 100 times in the Project. The Architect wants to see both "Hoods" and "Openings", the structural engineer only wants to see the "Openings". They are both in the same Project Host Model. The only way to solve this is to create a Structural view and an architectural view. The Host Family view options only offer to change visibility of the nested families through "detail level". So the structural view setting is forced to be "coarse" or "medium" in the View detail level, and the architectural view is forced to be "fine". But this is a too rough differentiation, because this way a lot of other Detail elements and other families is hidden from the structural engineer ins his view. The Architect will have a problem when viewing the top floor, where he will only wants to see to see the "Roof Opening" but will see both the "Hood" and the "Opening". He could then switch to a coarse view but will loose a lot of Detail elements and his Top Floor Layout will look really different from his other Floor layouts. So please add more visibility options to nested families, so that we can filter some of the nested families out with the project view filter! I have tried to make the nested families to "shared families" in the hope to be able to filter them out in my project view based on shared parameters. But when the the nested families are shared I cannot link their parameters with the parameters from the host model. Please make nested families (which are shared) able to link their parameters with the parameters of the host family.
