How to compare 2 objects apparently identical
Is there any way to compare and extract differences between two objects that are supposed to be identical, and yet they are not ? 2 beams have the same properties, are located between similar walls, but the beam-wall joins are not identical. One join doesn't cut the beam at wall face, and the beam overlaps the wall. Cleaning the join doesn't work. Neither Align, nor Trim/Extend.
