Coloring schemes for rebars in Revit by default
We need coloring schemes for rebars by default (ootb) in Revit for easier understanding of rebar tessellation and/or clashing in 3D views. OOTB Coloring schemes should by : colors by partition, colors by diameter, colors by rebar mark. Creating color filters is tedious, and each company may choose different color schemes. We need an Autodesk standard (template) for coloring schemes, so that all companies could use the same coloring schemes worldwide.
Comentarios
Could You add Rebar Color shceme by diameter for 3D and 2D
and aslo for BD in the new feature see attached
