Steel plates are created mostly with pick-plane and reference-planes, but something the thickness of the plate is extruded in the wrong side.
Plate don't admit a negative value for parameter of thickness, so it will be very useful if the user can select a option to flip the plane of reference, in order to make all the plate have it's thickness in the correct side.
