Easy way to stack several notes on top of each other
We need an easy way to stack several notes (multiline texts) on top of each other parametrically. And if we choose a certain note NOT to be visible on a certain stage, we need the other notes to fill in the empty space created by the "invisible" note.
This is possible in Tekla by simply aligning the notes to a page corner. Notes will be (in)visible in the order they were added to the page. If one note is marked as invisible, the other notes will self-realign to fill in the gap left by the invisible note.
