Layers in the DWG exported from Revit with linked RVT and DWG should be visible
On behalf of customer:
Layers in the DWG exported from Revit with linked RVT and DWG should be visible instanteniously and assigned correctly.
At this moment the layers are tranferred correctly, but only the for the main model are visible instanteniously in AutoCAD. The linked DWG or RVT are blocks or XREFS and are placed on Layer 0. They have to be exploded/edited to see its properties.
It is crucial for keeping DWG drawing AIA standards.
