Allow Revit Worksharing Monitor to be downloaded as an App from the Autodesk App Store. In my case, specifically version for Revit 2019.
Hi Paul,
This is an alternative to the work-sharing monitor if you're working on BIM 360 projects with a team. Thought it might help.
https://apps.autodesk.com/RVT/en/Detail/Index?id=2644980570425963717&appLang=en&os=Win64
help
