Systems Classifications
In Revit MEP, Storm & Sanitary piping have the same system classification, both are defined as sanitary.
Is there a chance  Autodesk, to come up with a separate system classification for Storm?
In real world application Storm is a separate , independent system from sanitary.
And in Revit, to separate these two (sanitary from storm) can turn into a time consuming process, by creating different filters to have them to show independently.
Comments
With limited system classifications, is there any intent to include additional system classifications? Additional systems should include: storm, process waste, fuel gas system (for natural has & propane), medical/lab gases, and there are others that would be desired.
This is just a bit of what is used in the water/waste water treatment engineering industry.  a clear way to know what system to use for any of these would be great.
