Design Option elements should populate schedules in the Main Model
I use Design Options to create multiple plan options for home builders. Some of the builders have upwards of 20 options added to the completed plan sets. I place those option views on separate sheets from the main floor plans. I use letters & numbers to tag windows & doors, then place a window & door schedule on the plan & elevation sheets. My issue is this --- if a design option includes adding a window or door that does not exist in the Main Model, that optional window or door will not populate the window & door schedules of the Main Model. So, I can tag the optional element like I do in the Main Model, but the element will not schedule in the Main Model. I know I can create a schedule for a specific design option, but I don't want to have multiple window & door schedules that need to be placed & aligned on multiple sheets. I want all elements in the project, Main Model and Design Option, to all populate only the Main Model schedules.
I've searched Ideas and Forums for this issue, but didn't see my specific concern.
