Search and replace should cover formulas
It would be helpful if there was a search and replace tool inside revit that allowed not only to process text entities but cover everything that is text. Right now I would need that to edit the formulas inside calculated values in an annotation. I would not mind being asked whether I wanted families, views or sheets that contain the search string also altered.
