We Should Have a Calculator
if autocad have it then why wouldn't revit? XD
Comentarios
I voted for this because, while pretty much any formula can be entered into a dimension or numeric field in Revit, a lot of the time my calculations are four- or five-step operations, and I'd like to have the equivalent of a calculator's paper tape as documentation of how a particular value was arrived at.
Do you know that you can type a sum into any number dialog box - this would act as a calculator.
You just need to start with an = sign.
i.e. instead of typing 4 into a dimension, you could type =2+2
no sir, Oh my goodness! this is really helpful
Thank you!
