Add Room Bounding Parameter to Railings
Add a room bounding parameter to railings. Allows for landings, mezzanines & interconnected floor spaces to be modeled and tagged as rooms without adding room boundary lines to the model.
Comentarios
I would like to have Room Bounding checkbox for Railings. It is very helpfully to make balcony or terrace areas.
if it is glasses, i would use a curtain wall instead of railing.
Yes, you right. I do the same. But I don`t want to use for it something other. I would like to use railings, exactly. I want to change types (glasses or iron patterns) without lost area.
IMHO, don't get too caught up on category types, the model will speak for itself. I use different categories regularly, (e.i; Railings for most profile based extrusions).
That's what Room Separation Lines are for. Very handy. Use any kind of railing you want, or a line of bushes!
Sometimes Room Separation Lines is not working properly, because they glue to the end of walls.
You can Hide them and they will still function to define a room.
Sure, I can. I told about the correctness of this method. Color fill of this room is not right. And the main thing, what I don't like, is Room Separation Lines every time trying to make my identical Floor Groups to unique.
heloo sir
please i have a problem with my revit version 2020 , when i draw a wall the lines do not appear clearly or appear like a discontinuous line.
can you help me or give me a link or an address to send my question to someone can help . thanks for you comprehension
yassine, you're in the wring forum
This forum's purpose is to suggest ideas to imporve REvit
For general Revit help, I suggest you post on either the Revit Forum.org
https://revitforum.org/forumdisplay.php/2-Architecture-and-General-Revit-Questions
or the Autodesk Revit community page
This option is a true emergency !!! Think to people drawing housing and dealing with multiple balcony and terraces !
Observer
Observer
why isn't this updated yet?!
The "Room Bounding Parameter to Railings" would be a really helpful tool, so that we won't have to do 'Rooms' by room divider. It will save a lot of trouble, during the period of design and changes.
We really need this. For now, We use hundreds of room seperations lines. Please Make a room bounding parameter for railings.
