Clipping box for legends
The legend views are important elements in the presentation of plans in revit, therefore to improve the functionalities of the same you should consider a clipping box as in the plan or section views, this to be able to make multiple legend views for different planes, for the reason that the planes do not have the same measurement and it is necessary to create different legends if they do not fit.
In addition, this could increase the functionality of the legend views in the development of construction details with imported elements, being able to add, cut these details to different planes without restriction of size or position.
0
votos
