Option to detach View(s) from the model
It would be very useful to have an option to detach view(s) from the model. Meaning converting it to drafting view without having to export it to dwg, then import it back to Revit. This way we could produce typical repetitive details for many similar elements like walls, slabs, attic, etc. This way we could add such typical details on many sheets, even by using Dynamo scripts if necessary.
Comentarios
