Toggle "Thin Lines" tool without ending current command
I would like to be able to toggle "Thin Lines" Tool on and off, without it ending the command I'm currently using.
I often need to place or move something in a precise place and with the normal size of lines it's not always accurate (even with snap). So I click on "Thin Lines" but that end the command and I need to start again.
