OneFilter extesnion should be standard selection method
OneFilter extension from DiRoots is so much better than the standard Revit selection / filter option. It is far more easier and natural to first select the object(s) of interest, THEN apply a command or modifier to that, compared to Revit classical style (activate command -> select tons of stuff -> filter out object(s) of interest).
