View Range issues
The current issue with the View Range, which work for the architectural plans but does not work (and neither its graphics) with the Reflected Ceiling Plan and some other views like the Mechanical Plans, etc., is this not something the Revit community can get together to see if Autodesk finally resolves it?
Comentarios
This would probably be considered a bug fix and not a new feature that would help rent out the piece to new users. Still it would be brilliant if this were given some attention.
