View Filters - be able to filter elements by Phase
I would like to be able to filter elements by phase to be able to override in a view or in a view template the appearance of specific element (for example change the line width of a window, make the pattern transparent, etc.)
I use Phase filter, so I do not want to get rid of it (as propose the post https://forums.autodesk.com/t5/revit-ideas/phase-visibility-control-via-view-filters/idc-p/6525360#M...), I only want to be able to override specific elements by their phase and keep using phase filter too for global overide.
Comentarios
This was added in 2022!
El estado se ha cambiado a: Implemented
